Need wood source
glennh | Posted in General Discussion on September 9, 2005 08:07am
Hi all,
I’m trying to find some 100% clear white pine in 1×6 dimension to
finish some sills for Pella-like windows. And I’m having difficulty
in the Phoenix area. Even the specialty yards have only a clear
rotary cut sugar pine which I think would stain up awful.
So….does anyone know of a source; a good supplier of woods that I
can go to on the web, etc. and order up some? I’m getting tired of
looking and having the project delayed continually.
If not, can anyone suggest a different clear wood (basswood, etc) that
I might substitute without running into stain matching problems?
Thanks VERY much for any suggestions you can give.
Glenn
  1. calvin | Sep 09, 2005 08:52pm | #1
    Hello again,   glenn, there is a pine from New Zealand called Radiata pine that is readily available here in NW OH.  Check with a local good lumber yard.
    Quittin' Time
    Sphere | Sep 09, 2005 09:27pm | #2
    Bateman Bros Lum Co in Chalfont PA, get the 5/4 SUGAR PINE..16' by 14" all clear and aircraft quality straight .
    dmt | Sep 09, 2005 11:26pm | #3
    Try http://www.walllumber.com (That is Steve Wall Lumber in NC.)
  4. MikeFitz | Sep 09, 2005 11:48pm | #4
    Try a web search for white pine flooring, then talk to the high end flooring companies (mostly in the N. East) and see if you can get clear flooring without the relieved back.  I would bet they could do it for you, although I'm sure at a premium.  You could also get some clear flooring and run it through a planer to take off the back relief.  Carlisle, Conklin, etc. are the types of companies I was thinking about.
    Mike
    BillHartmann | Sep 10, 2005 12:07am | #5
    " Even the specialty yards have only a clear
    rotary cut sugar pine "
    How do you have rotary cut wood except for a veneer?
    I wonder if you are using the wrong term?
    1. glennh | Sep 10, 2005 12:56am | #6
      Yes, I am. I guess the best description would be "non-quarter sawn"But I've worked with this cut of wood before. It doesn't have the
      neat parallel lines of 1/4sawn, rather has wavy wilder bands. But
      the wood I've looked at has big solid areas of the darker grain, like
      4x6 ovalish areas. Perhaps non-1/4 sawn areas of trees with thicker
      growth rings? Don't know, but that's not what I want and it's
      what I've found at Lowes, HD, and a specialty hardwood place that
      also carries pine.
        BillHartmann | Sep 10, 2005 01:21am | #7
        That would be plain sawn or flat sawn.BTW on softwoods qtr sawn is often called vertical grain.
  6. Piffin | Sep 10, 2005 10:17pm | #8
    Are you looking for 8/4 for exterior historic sills, or 5/4 for interior millwork?
    The white pine is a poor choice for exterior sill work, IMO
    But maybe you can try woodweb
    http://www.woodweb.com/SiteMap.html
Two Ways to Test Windows
  • The New Old Colonial
