In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
New Fir Treds
| Posted in Construction Techniques on December 2, 2002 07:51am
I need to replace a couple of fir stair treds. The existing treds are 1-1/8 x 10 x 42 inches. I was thinking of using a trickness planner to take 2 x 12 clear fir boards down to 1-1/8 and then shapping the bullnose by hand to match the original profile. I’m concerned that the boards may cup or split after being planned down. Does anyone have experience making stair treds out of 2 x 12 clear fir lumber?
  1. suntoad | Dec 02, 2002 09:37am | #1
    I've replaced a few fir treads in my own house.  I edge glued 2x4 clear fir then planed to proper thickness and routed the nosing.  Sanded and gave 3 coats of Poly.  Solid, stable, and looks so good, it makes the rest of my treads look like doo-doo.
  2. MisterT | Dec 02, 2002 02:13pm | #2
    If you cannot find a quarter sawn 2x12:
    Take your 2x12 and rip it into 1-1/2" pieces.
    them rotate each piece so the grain is vertical and glue them back together.
    Your tread will be much less prone to cupping this way.
    MrT
    Do not try this at home!
    I am a trained professional!
  3. Jamie_Buxton | Dec 02, 2002 11:11pm | #3
    This may be obvious, but you should start with dry lumber.   Around here, 2x12 fir is almost always green.
  4. daycon | Dec 03, 2002 03:36am | #4
    go tooo the lumber yard ie the real one. ask for 5/4 fir stair tread, write check, go home, install, finish, end of deal.
    1. Piffin | Dec 03, 2002 07:46am | #6
      Daycon1 passed the test. All you other yahoos stay after class..
      "The first rule is to keep an untroubled spirit.
      The second is to look things in the face and know them for what they are."
      --Marcus Aurelius
      1. inRitchie | Dec 03, 2002 08:49am | #7
        Thanks for all the advice. I would definately rather buy a 5/4 tred than make one. However, such a piece of lumber seems to be a very rare commodity in these parts. A couple of the local yards offered to glue them up for me. I think I'll try a couple of the suggestions and see what happens.
        1. UncleDunc | Dec 03, 2002 09:31am | #8
          No reason to limit yourself to what's available locally. If you can find it online, even with cutting charges and shipping it would be less hassle than some of the alternative suggestions.
          1. fredsmart48 | Dec 03, 2002 10:50am | #9
            "No reason to limit yourself to what's available locally. If you can find it online, even with cutting charges and shipping it would be less hassle than some of the alternative suggestions."
            That is true but the other way he gets to play in shop. :)
  5. r_ignacki | Dec 03, 2002 04:21am | #5
    plane off 1/4".
    Let the boards acclimate to the house.
    then finish the job.
    listening for the secret.......searching for the sound...
Detailed Assemblies for an Airtight Small Home
Drawings and details for building a high-performing slab-on-grade foundation, double-stud wall, and truss roof with nontoxic materials
  • Decompartmentalizing a 1940s San Francisco Home
  • Podcast 460: PRO TALK With Builder Keith Bohling
  • How to Frame an I-Joist Roof
  • Designer Kitchen Cabinets on a Budget
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Tool Guide 2022
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
