New Roof Leaking
TMO | Posted in General Discussion on August 3, 2006 11:47am
Ok, So I have a customer purchased a roof through home depot. The Shingles are GAF and appear to be installed properly.
I hope I can paint a mental picture cause I didn’t take any but the installation layers go like this
When you look at the edge of the roof you 2″ white steel drip edge, a dark fibrous looking 1/2″ under layment and then the shingles. When I asked the home owner what that was for she said it was for ventilation.
Is anybody familiar with this type of “roofing system” If so where would I get more info. I’ve been to the GAF site and didn’t find any ventilation board in 4×8 sheets.
It is over a moblie home built for a shingled roof system.
As I mentioned the roof leaks and it is my belief that the vent board should be under the drip edge, if that is, in fact what it is.
  1. Piffin | Aug 04, 2006 12:37am | #1
    I'd need a scetch or photo to understand that one
    1. TMO | Aug 04, 2006 05:06am | #2
      I figured but I thought I'd try. I finished my project for her last week and can't get back for a bit. According to hte customer it is a roofing system but I have never seen anything like it.
      Think about seeing 1/2" plywood above the drip edge but below the shingles. Except the plywood is black and looks a bit like fabric.
      1. MojoMan | Aug 04, 2006 05:19am | #3
        Could the ventilation material be 'Cedar Breather'? It's a fiberous plastic mat that supposed to go under cedar roofing shingle and shakes.Where is the leak? If the shingleas are installed properly, I don't see how this extra layer, by itself, would cause leaks.Al Mollitor, Sharon MAhttp://moosehilljournal.blogspot.com/
        1. TMO | Aug 04, 2006 05:23am | #4
          It could be that. If this extra layer isn't sealed to the drip edge somehow it seems to me that wind and rain could combine to make some leaks around the perimeter. Which is where the leaks have appeared. She said she noticed the leaks around her windows and the cieling is staining around the perimeter.
        2. davidmeiland | Aug 04, 2006 05:24am | #5
          Would HD be using a product like Cedar Breather? I'm guessing it's homasote, but let's wait and see if any photos are forthcoming.
            Sphere | Aug 04, 2006 05:29am | #6
            Same thought, but lacks evidence.
            Cb over De is OK, but w/shingles? no way. Ya can't.
            I guess ya could nail over Homasote. But not in my world.
            " I am not an Activist, I am, a Catalyst. I lay around and do nothing, until another ingredient is added"
          2. TMO | Aug 04, 2006 05:30am | #7
            I could try to bounce past there tommorrow.
            Maybe I'll call the homeowner and see if she can post some photos
            I'll try.
            Tain't homasote.
            Edited 8/3/2006 10:31 pm ET by TMO
            Edited 8/3/2006 10:33 pm ET by TMO
            Dinosaur | Aug 04, 2006 06:44am | #8
            I don't know what homasote is; must be a regional term we don't use here.
            Could it be 'Black Joe'? This is ½"-thick tarred pressed-cardboard often used as sheathing on cheaper houses. I have seen it used on roofs as an exterior 'insulation' layer (it gives about R-2) but there's no way it should be over the drip edge. It's tarred, but the edge will soak up water like a sponge after a freeze-thaw cycle.
            By itself, it shouldn't cause leaking if the shingles are properly laid over it and the flashings are properly one. But if somebody put the drip edge below it, I'd suspect some other mistakes are likely to have been made, too....
             Dinosaur
Double-Duty Large-Jaw Pliers
Klein's 10-in. plier wrench has a toothed V-jaw for grabbing pipe and conduit, or can be flipped around for a parallel, smooth grip.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
