JUST GOT A CALL FROM MY LUMBER GUY. SIMPSON STRONG TIE NO LONGER WARRANTEES THEIR CONNECTORS WHEN USED WITH CBA TREATED LUMBER. WHAT ABOUT ANCHOR BOLTS, STABS, NAILS, LAGS, ETC? STAINLESS ALSO EXCLUDED! BE CAREFUL WITH THOSE JOBS SPECIFIED IN CBA.
-GEORGE MORTER
EUGENE, OR
I new that most were, but didn't know it applied to the stainless line.
Never be afraid to try something new. Remember, amateurs built the ark, Professional build the Titanic.
morter.. i know CCA.. but i'm not familiar with CBA treated.. what is CBA ?
http://forums.taunton.com/n/find/findRedir.asp?webtag=tp-breaktime&mg=95786992-11C1-4461-A4FA-72EAA524BE6F
A little research (very little) showed that only the ACQ would have problems with galvanized fasteners, etc. Why do you suppose that Simpson would now have problems with CBA, a supposedly benign treatment and OK'd for galvanized.
Gonna be a nightmare for the code writers and code enforcement guys (and us who still have to build things and hope they stay together)<G>
Edited 5/12/2003 7:32:02 PM ET by Ralph Wicklund
From Simpson Strong-Tie's PT wood/corrosion FAQ:
http://www.strongtie.com/ii_corrosion_info.html
"Are these newer products more corrosive than CCA?
Testing has indicated that Alkaline Copper Quat (ACQ-C) and Copper Azole (CBA-A and CA-B) are more corrosive to steel and some protective coatings applied over steel than Chromated Copper Arsenate (CCA-C). ACQ-C, CBA-A and CA-B may have different corrosion rates. Contact the treated wood chemical supplier for more information. "
Elsewhere they generically reccomend hot-dip galv. or SS, as opposed to electro plate galv. for any PT wood. But they're pretty consistent in deferring to the preservative maker's fastener reccommendations.
http://www.strongtie.com/ii_PTWoodFAQs.html#linksIf everything seems to be going well, you've obviously overlooked something.
