I’m remodeling room in our house. It has 40 year old t&g with 4 or 5 coats of paint that is not in good shape (the last coat is latex). There are alot of pock marks to get rid of.
Any suggestions?
I considered using water putty, but its short work time is not ideal. Question: Will durabond function? I also heard of a vinyl spackle for exterior work that might function.
Any suggestions will be appreciated.
You might want to look at Wall Liner or Paper Liner. It is a heavy duty wallpaper like product that you put up like wallpaper to give you a fresh surface to work with.
What is it you are trying to do with it?
Just painting?
Remo to me generally gets things torn down to the studs. I think that would eliminate your problem with the paint job.
