Small bath ceramic tile job.
Tore down to floor joists and ready for subfloor.
Most recommend minimal inch and a quarter thickness for subfloor.
Besides a layer of 3/4ply and a glue/screw to 1/2, is there a single sheet product available as an adequate subfloor base?
Thanks.
I thought 3/4 inch ply and 1/2 inch durock mudded and screwed satisfied the inch and a quarter requirement.
I know it's still two steps, but I'm assuming you were gonna lay down cement board on top of even 1 1/4 plywood.
Edited 4/10/2008 1:01 pm ET by IamtheWalrus
Didn't know that about the durock product.
As I understood it the inch and a quarter is strictly for a strength factor of which a cement board product does not supply but I've been wrong before. Once.
Rethinking the strategy in such a small area I'll probably just glue and screw and be done with it then use a quarterinch cementboard.
Unless something better shows itself.
Click here for access to the Woodshed Tavern
You're right; the Durock isn't structural.
You can get 1¼" ply (probably need to special-order it, tho). It's used a lot by concrete contractors here for forms. For a big job, it might be worth it. I wouldn't bother for this small job of yours.
Run the joist spacing and scantlings through the JohnBridge flex calculator (http://www.johnbridge.com/vbulletin/deflecto.pl) then decide what you need for subfloor, and scroo-n-gloo it.
I would not use ¼" cement board; it's too thin. I had bad experience with the screwheads pulling through it. Whole job then disintegrated. Lucky it was a small area in my own place and I had leftovers or it woulda cost me big time.
If you don't have room for another ½" of thickness on top of the specified subfloor, skip the cement board and lay down Ditra. ¼" thick and as water resistant as the CBU if not moreso. Also functions as a bond breaker. For a small room, the cost isn't an issue. +/-$2 per SF plus you triple your thinset consumption (with CBU you double it anyway...).
Dinosaur
throw some cross blocking in there... 2x4's are plenty large enough...
use 3/4 ply....
and use Hardi instead durorock
PL the Hardi down....
WOW!!! What a Ride!
what OC ya got....
WOW!!! What a Ride!
Who is "most" ?
3/4 Advantech and 1/2" WB has been successful for years and years.
is there something special about the tile ?
carpenter in transition
Got it.
Thanks to all.
For joist on 16"
If you are installing DIRECTLY on wood the TCA requires an 5/8" exterior grade plywood subfloor and 1/2" exterior grade plywood underlayment. The screws for the underlayment should not go into the joist, but into the sub-floor. While thee is a combination 1 1/8" subfloor/underlayment I don't think that it will hve the decoupling of any splices. So I would not recommend it unless you can use a singple piece.
For use with CBU's or Fiber Cement backers then you only need 5/8" plywood subfloor plus the backer.
