I’m looking for opinions on resurfacing the old cracked and spalted concrete walkway on our house, c.1910. I’m considering a concrete/epoxy system from a contractor using a CTI brand material. It is trowled on with multi-colors or layered effects to imitate stone, brick, etc. after pressure cleaning the old concrete but is only about 1/8 inch thick. The contrator made a good case for its durability and the samples I’ve seen look good. It comes with a 10 year guarantee and he’s been in the business for some time so I can check on older work. Anyone out there with experience on this or similar material system?
I'm looking for opinions on resurfacing the old cracked and spalted concrete walkway on our house, c.1910. I'm considering a concrete/epoxy system from a contractor using a CTI brand material. It is trowled on with multi-colors or layered effects to imitate stone, brick, etc. after pressure cleaning the old concrete but is only about 1/8 inch thick. The contrator made a good case for its durability and the samples I've seen look good. It comes with a 10 year guarantee and he's been in the business for some time so I can check on older work. Anyone out there with experience on this or similar material system?
Mike,
Recently saw a system the same or similar. It was explained to me to be the "Dryvit" coating over concrete. It was in the shop of a ceiling/drywall contractor. Saw all the patterns in a few colors. Looked good and was rec. plenty of abuse. If it's the same kinda stuff, then it might be an Idea. However, on spalling concrete, I'd be a little wary. Are you in a freeze thaw area?
Be carefull trying to top off a pc. of crap. Might get another opinion. Best of luck
