Options to replace radiators in kickten?
mnhunter2 | Posted in Energy, Heating & Insulation on October 5, 2004 06:11am
Need ideas on replacing the old hot water radiators in the kichten that we are remodeling, we will not have any wall space for them so its been suggested that we could run the hot water lines in the floor along the top of the joistes and then insulate them so the heat will be directed up into the floor of the kichten.  Is there any type of raditor that would fit under the toe kick?
  1. csnow | Oct 05, 2004 10:45pm | #1
    Hydronic convectors in the toe kicks is the common solution to this problem.  You will not have any problem finding them.
    A radiant floor would be much nicer.
