+ OR – ENGINEERING QUESTION
Harborman | Posted in General Discussion on June 4, 2002 12:37pm
While looking at the specifications for a Laser level the specs read + or – 5/16″ in 100 feet.  Now does this mean that the instrument could be off 5/8 of an inch in 100 feet or only 5/16 of an inch.  I’m just curious.  Best Regards,  Dale Buchanan
  1. MisterT | Jun 04, 2002 01:17am | #1
    It means that the max error over 100' will be 5/16" in either the + or - direction. But if you rotate the instrument 180 o and the error is in the opposite direction youwill get an error of 5/8 over 200'.
    BTW 5/16" per 100' seems like a lot most lasers are in the 1/16" to 1/8" range.
    My two cents worth, +or - a buck or two!
    Mr T
    Do not try this at home!
    I am a trained professional!
      Harborman | Jun 04, 2002 02:28am | #2
      Mr. T:   Thanks, I don't think this instrument is accurate enough for me.  I have a Pentax theodolite that I use for real accuracy, sometimes hard to work with alone but I love the accuracy.  Again Mr. T I appreciate the information.  Best Regards,  Dale Buchanan
      1. Piffin | Jun 04, 2002 04:47am | #3
        5/16" in 100' is a little sloppy, especially when you figure that the dot can be a quarter inch bib at that distance so you can add a little for operator error. Plenty of optical levels were used for years with accuracy ratings of 1/4"per100' though and God knows they had plenty of opp-errors too.
        1. bearmon | Jun 04, 2002 05:45am | #4
          I have a Nikon optical that claims a 1/32 or 1/16 error over 100', I can't remember which.  No slop with the beam either, nice sharp cross-hairs.  Of course it takes two to operate.  5/16 seems like a lot.  Bear
          1. OneofmanyBobs | Jun 04, 2002 12:23pm | #5
            The laser levels are handy in a kitchen or someplace
            like that. As far as a surveying instrument, not so good.
            Typical accuracy is 1/4 inch per 50 feet. Some better, some
            much worse. No way to make the dot smaller. In fact, they're
            more accurate if the dot is bigger. But they're handy for ####lot of things and don't need 2 people to use. They're not
            really a precision instrument like a transit. They're also
            a fraction of the price.
