Outbuilding: DIY SIPs?
Biff_Loman | Posted in Construction Techniques on March 21, 2008 02:51am
I’m dreaming of summer, as usual, during the winter. I don’t dream of winter during the summer, let me tell you.
Anyway: if I wanted to construct a small, insulated out-building, does it make any sense to grab some EPS and OSB and glue up one’s own SIPs?
I’d want OSB on the inside anyways, and I need insulation anyways. See where I’m going?
    MarkH | Mar 21, 2008 02:53pm | #1
    Ask Frenchy.
    Bump
      FatRoman | Mar 21, 2008 02:58pm | #2
      You're wanted on the white courtesy phone...'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
  2. frenchy | Mar 21, 2008 05:22pm | #3
    BiffLoman,
       I'm sorry but no..  it's been tried a lot and never succesfully.
      In addition to the three things mentioned, you need pressure and heat.  A way to squeeze and heat the "glue" to fully bond the foam with the OSB.
     Successful SIP's  have the correct amount of pressure and the right tempurature. plus the "glue" is critical..  Most glues weaken the bond betwee foam and OSB rather than unite.   While there appears to be no one way to make SIP's, there does apper to be only a limited number of ways which will work succesfully.
      Is there something else that will work for you?  I don't know, could you tell me more about your plans?  This outbuilding is it fixed in place or does it need to be moble?   how durable do you need it?
    1. Biff_Loman | Mar 21, 2008 05:27pm | #4
      I was really just curious.  When (that is to say, if) I build it, I can frame it normally.
      1. frenchy | Mar 21, 2008 06:09pm | #5
        BiffLoman,
          Could you build it with ICF's?  Or does it need to be moble?
          The reason is while I built my house with SIP's I built the foundation with ICF's   knowing then what I know now I would have built it all with ICF's
          ICF's are superior because they have up to a 4 hour fire rating,  they will withstand 200 MPH winds,  very durable.  They are extremely easy and fast to build with.
        1. TomW | Mar 21, 2008 06:11pm | #6
          ICF's????
          For a shed?????
          1. frenchy | Mar 21, 2008 06:29pm | #7
            TomW
             Insulated Concrete Forms.  Giant foam leggos used to build house with..very quick, easy, and fast way to build..
             He's calling for a well insulated building.. That's why I kept asking about mobility.
            Edited 3/21/2008 11:30 am ET by frenchy
Drafting the 2027 IRC
  • The New Old Colonial
