Need information on building paint room. (electrical, ventilation and exhaust)
From plumbing failures to environmental near disasters, OHJ staffers dish on our worst and best moments.
Peter, a few years ago I had the experience of erecting a pre-fabricated paint spray booth. The issues of enclosure, pre-fltering, exhaust filtering, differential pressures, heating, etc. are pretty complicated, and the manufacturer had these worked out in the design. I just did a search using the words "paint spray booth" and came up with several manufacturers. You might want to check some web sites. These could give you some clues as to what you need to consider. IF you are going to build it yourself, I urge you to read up on the applicable OHSA regulations (and there are plenty of them).
Hope this helps, Steve
