I have a 1/2 hp. paint sprayer (recon.) that I’d like to use as a pressure washer at times, has anybody had any luck doing this? I’d like to avoid buying another tool that might only get used 2-3 times a year.The sprayer is apx. 3 gpm., 0-2500 psi.. What if I filled a 5 gal. bucket with soapy water? and some way to keep it full, After all, I have to clean it this way. Any thoughts?
I have a 1/2 hp. paint sprayer (recon.) that I'd like to use as a pressure washer at times, has anybody had any luck doing this? I'd like to avoid buying another tool that might only get used 2-3 times a year.The sprayer is apx. 3 gpm., 0-2500 psi.. What if I filled a 5 gal. bucket with soapy water? and some way to keep it full, After all, I have to clean it this way. Any thoughts?
volume would be the question. Are you sure your 1/2 hp pushes 3 gpm and not .3 (point 3) We have a 3/4 hp and it will only push 1/2 gpm.
