I have a few places where I need to put up gutters but I want them the same color as the facia so they blend in. Any suggestions? Anyone ever make them out of wood?
Thanks,
Steve
Thanks,
Steve
There's a constant source of clean water for you to use, and all you have to do is collect it.
Aluminum, galvanized, and copper are all paintable. Wooden gutters are available, mostly in the north east (I've only seen them once in my area), but they appear to be a maintainace headache.
ANY gutter is a maintainence headache!
Wood gutters are common in the northeast. It can be a pain to try retrofitting them into a house that wasn't designed with them in mind though. I oil the insides with linseed and paint the exteriors with the paint before installing. The owner needs to clean them every year (just like every other kind of gutter) and re-oil them every two years and they'll last a lifetime.
Good painter can paint any type gutter material but vinyl - well maybe vinyl too.Excellence is its own reward!
Sure, those metal gutters are paintable. We usually paint them to match and, as a matter of fact, are going to start installing some tomorrow (God willing and the creek don't rise)that we sprayed two weeks ago. We also paint our fascia cladding and drip edge. We try to spray them at least ten days prior to transporting to the site or installing.
We always use a primer designated as a high tack primer designated for glossy surfaces though and never rely upon painting over the existing paint or primer on any metal surface. On galvanized or aluminum we usually use a zinc chromate primer and on painted/primed steel, we use Zinnser's 1-2-3 primer,Xim, or something of that sort.
Thanks for all of the feedback. I got the impression gutters wouldn't hold paint but I'll check into the primer.
Thanks again,Steve
Gutters are a challenge.
Wet area
pounding by ladders
ice and snow
acid from leaf buildup
did I mention wet area
That's why it's better to paint first, when you can do good prep and prime. Hastily applied in place with poor prep and it will be the first paint to fall off the house. Excellence is its own reward!
