In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
painters – Mureusco????????
Piffin | Posted in General Discussion on November 2, 2002 08:57am
Back in the thirties, a lot of painters here used a chaulky kind of paint that was mixed on site with water and the powder. It leaves such a chaulky finish that most modern paints don’t stick to it. Painters here prefer to remove the plaster it is on and re-rock it or rock over it to get a good surface.
My question is whether anyone has experience with a method for getting paint to stick to it. I have a job with a couple of rooms that prrresent other problems with removing or covering the surface material.
I was thinking of something like having the painter scrub down the walls with a mild acid wash, rinse, and roll or spray a consolidant/bonding agent, then patch holes with durabond and new primer plus paint.
Any comments?
  1. jc21 | Nov 02, 2002 09:06pm | #1
    Calcimine?
    1. Piffin | Nov 02, 2002 10:39pm | #2
      maybe. As I understand it, Muereusco was a product name back then. Is calcimine a catagory or product name?.
  2. MarkH128 | Nov 02, 2002 10:54pm | #3
    http://freepages.history.rootsweb.com/~mchub/carteret/benmoore.htm A little bit of history about Muresco.
    Try covering it with MOORCRAFT SUPER SPEC ALKYD CALCIMINE RECOATER. I think Muresco is calcimine, but not sure. I'm not even sure how to tell if you're looking at calcimine. I think calcimine may be an urban legend, everybody talks about it, but how many times do you paint over something that was last sold 80 years ago or so?
    Edited 11/2/2002 4:12:56 PM ET by MARKH128
  3. MarkH128 | Nov 02, 2002 11:20pm | #4
    OK, I'm certain Muresco is calcimine now. Chalk and glue with some color. Does not hold paint because of the softness and surface tension of the glue. Here is some more reading material.
    http://www.plasterlord.com/notebook/fcalcimine.htm
    1. Piffin | Nov 02, 2002 11:53pm | #5
      Thanks for the direction. Those guys at Lord and Plaster are right down the coast from here and that was a very informative site. Another site I came across says that it is made mostly from Irish moss and Pennsylvannia clay. Since clay and chaulk are both alkaline, the acid wash idea probably has merit and the lead for the right overvcoat product sounds good.
      I really appreciate it all..
      1. MrPita2 | Nov 05, 2002 01:21am | #6
        A very brief answer:
        http://www.paintquality.com/faq/Interior/calcimine.html
        from what I've found to be a good resource:
        If everything seems to be going well, you've obviously overlooked something.
        Edited 11/4/2002 5:22:20 PM ET by Mr. Pita
        1. Piffin | Nov 05, 2002 01:48am | #7
          Thanks, I'll keep that one bookmarked.
          "The first rule is to keep an untroubled spirit. The second is to look things in the face and know them for what they are." --Marcus Aurelius
          1. jc21 | Nov 05, 2002 10:40pm | #8
            http://www.sherwin-williams.com/Contractors/res-com/products/loxon.asp#
            is something else that you can use on calcimine ceilings. I usually scrub it off as described in a previous post. That and Loxon or the Bennie Moore  product should give you good results. The scrubbing is nasty work.
Designer Kitchen Cabinets on a Budget
This Danish manufacturer has found a way to bring modern, architect-designed cabinetry to the masses.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
