Can accoustic ceiling tiles be effectively painted, or will they absorb too much paint and look bad? What’s the best approach?
Kilz makes an aerosol paint just for this purpose. But that is for touch-up and spotting. If you plan on painting an entire ceiling, I'd suggest you shoot it with a HVLP gun. These tiles usually require a second coat.
If they're just yellowed and mildly dirty you can spray them with any latex flat or low lustre. If there are waterstains or smoke deposits, use a pigmented shellac sealer/primer, then topcoat. You can use cheap equipment if necessary because the quality of the spray pattern won't show.
*Hi Rich, we posted at nearly the same time; I don't know that Charles would really need a HVLP, they're usually a little hard to find for rental. A Wagner sprayer would probably be ok, and if there is a lot to do, I would definately recommend an airless unit; much faster and easier to rent.
Can accoustic ceiling tiles be effectively painted, or will they absorb too much paint and look bad? What's the best approach?
