Can vinyl siding be painted? I have heard that it contracts and expands quite significantly with changes in temperature — but so does wood with changes in RH. Would a good latex not be able to move with the siding?
You can paint it with latex, but you have then thus defeated all of the "benefits" of the plastic menace. I.E. - no maintenance for life.
-Rob
*I suggest that you talk to a salesman of vinyl siding. I think you will find that it never needs painting. [I would hate to get caught sugesting doing anything but removing it, but if you don't tell any one I said so, I'd think about vinyl based paint.]
*Vinyl expands much more than wood so you need the best 100% acrylic latex for the best flexibility and longevity. Stay away from dark colors because of heat. I would want to paint a piece and check it for a month in the sun. You may need a good latex primer like Bullseye 1-2-3. Down the road you will need to paint again and when you add coats you increase the likelihood of problems. I dont think paint stripper will work real well.
Can vinyl siding be painted? I have heard that it contracts and expands quite significantly with changes in temperature -- but so does wood with changes in RH. Would a good latex not be able to move with the siding?
