We have been searching with no luck for some kind of manufactured kitchen backsplash “system”. A product that is either a solid through material, metal, laminated, etc. The product would come in 18″ tall by maybe 8′, 10′, or 12′ panels. Molding and trim pieces would cleanly cover cut ends, joined pieces, corners, etc. Lengths and outlet holes could be cut at the site. It seems there might be a market for something of this sort. Does anyone know of a source/manufacturer for this type of product.
Tin ceiling panels. M-boss makes them from aluminum with a variety of finishes and colors. They make them in sizes intended for exactly your application. It's a specific look though. May or may not appeal.
http://www.mbossinc.com/
Were looking for a product that comes in wide panels; 8'-12' long. Also were going for a clean modern look.
if U wanted tp pay me ...
I could install either solid surface, stainless steel (or other metals) and / or laminate backsplashes ... all with hidden fasteners.
Not sure what U are asking here.
restraunts have this stuff all over the world.
Buck Construction
Artistry In Carpentry
Pittsburgh Pa
What about using slatwall, generally seen in retail stores, or one of the modular products typically seen in garage storage systems?
Slatwall is available in just about any finish, a variety of duty ratings and materials, has a bunch of accessories available, easily joined & trimmed. Generally available in 4x8 (slats run the length) size at 3/4" thick.
There are some stainless systems, but I don't know about panels with them. Try a commercial kitchen supplier.
Solid surface could be used. You would just have to work with a fabricator to get it done right.
Laminate comes in lengths of upto 12-ft. Properly trimmed out it looks quite good. They have some metal surface that is hard to tell from the real thing.
I agree. Solid-surface and laminate are good choices.One way we used to build back in the 70s was to set bases, then the countertop, complete with integral 18" splash. Then set the uppers on that.The final step was to climb up on your tote with a couple of steel studs, your tinsnips, and your screwgun. Don't come down until the soffit is completely framed.It's a good system today if you do it right.Better yet, add Sarah Susanka's ( or was it Susan Sarandon's) system of installing a full-length block just under the uppers, with full-length plug-strip screwed to it. No worries about interrupting any backsplash designs like tile, etc. You also get way more outlets, and I've never had anyone complain that I gave them too many. She also angles the block downward a bit for better plug clearance and ease of plugging in.The big payoff for us is that, with a little extra spent on materials, we speed the process up big-time, and save on labor, fussing, and callbacks.AitchKay
I don't know if you have an IKEA nearby, but they sell long pieces of stainless steel to be used as a splash. I've used it once before. Easy to cut and looked great. I ran it in between walls, so I'm not sure if they sell a finish piece for the exposed end.
http://www.ikea.com/us/en/catalog/products/90075406
http://www.ikea.com/us/en/catalog/products/70059657
