Patching plaster
| Posted in Construction Techniques on April 13, 2005 03:24am
I suspect that this is really easy for you Yankees, but I have always dealt with sheetrock and this is my first experience with plaster.
30 YO house, the walls appear to be 3/8 sheetrock with about 1/8″ plaster skim coat.  The previous owner had a window unit a/c and a 220 outlet.  Both have been removed, and it’s time to patch the outlet hole.  Hee’s what I have in mind:  put a sheetrock plug in the hole and glob on some 20 minute Durabond, sand smooth and paint.  Do I need to use mesh or paper tape?  If so, do I need to chisel down the existing plater so the tape will be slightly recessed?
I’m sorry, I thought you wanted it done the right way.
  1. ruffmike | Apr 13, 2005 03:49pm | #1
    See the similar post in general discussions, one of the methods should work for you
    1. FastEddie1 | Apr 13, 2005 04:46pm | #2
      Is that "replastering exposed lath"?
      Still unsure if  I need to use joint tape.
      1. PenobscotMan | Apr 13, 2005 04:53pm | #3
        I use FG tape for a repair like that.  I don't recess it, but try to feather it out (quite a distance).  The bulge is nearly invisible.  And, yeah, durabond, not all-purpose (although you will probably want to use all-purpose or easy-sand for the finish coat -- easier to sand.)
        1. ruffmike | Apr 14, 2005 02:33am | #4
          Javier is on the money, I thought you were talking about patching the a.c. hole.
           Whenever I mix rock and plaster, I always tape seams. If it is a plaster patch I make a rough edge and use bonding agent, similar to stucco
          1. mikerooney | Apr 14, 2005 02:58am | #5
            If it is a plaster wall, you don't need tape.
            Plaster board, tape it.
            I like Imperial for patching up after elec., plumbers in an old house.
             People's dreams are made out of what they do all day. The same way a dog that runs rabbits will dream of rabbits. It's what you do that makes your soul, not the other way around.
                                            - Barbara Kingsolver
          2. FastEddie1 | Apr 14, 2005 04:29am | #6
            What's the diff between plaster and plaster board?
            I already patched it.  Put in a plug of sheetrock, two coats of durock with a layer of mesh tape on first.  Looks good.
Why the FHB Summit Is an Industry Event You Don't Want to Miss
The Fine Homebuilding Summit is finally back after a six-year hiatus — and it's going to be better than ever.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
