How do I connect PEX tubing to galvanized pipe?
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
IPT to compression fitting.
Andy
"Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein (or maybe Mark Twain)
"Get off your dead #### and on your dying feet." Mom
"Everything not forbidden is compulsory." T.H. White, The Book of Merlin
Thanks Andy. OK, what's IPT?
Paul
IPT - iron pipe thread.MPT - male (iron) pipe thread.FPT - female (iron) pipe thread.I belive that there is another one NPS - national pipe standard or something like that.That all refer to the common pipe thread that is tapered cut. Used for all threaded fittings (whether iron pipe, brass, plastic).But compression fit and flared fittings use a different type of thread.
Sorry for the jargon. Bill's right. Most PEX manufacturers make fittings for this purpose, and generic PEX fittings will also work. PEX is made to the same ASTM outside diameter as copper pipe, and although there may be warranty concerns, I've found that a compression fitting that works with copper also works with PEX.Andy
If you use a compression fitting be sure to use the tube stiffner insert to keep the pex from collapsing.
“It so happens that everything that is stupid is not unconstitutional.” —Supreme Court Justice Antonin Scalia
Isn't it only middle aged PEX that needs the t.... Ah, never mind.Andy
Andy,
Sounds like you have experience in that area.
BTW, how old are you?
Bryan"Objects in mirror appear closer than they are."
Klakamp Construction, Findlay, Ohio
Compression fittings work OK if you use the insert, but SharkBite fittings are the cat's azz.http://www.cashacme.com/sharkbite.phpPaul
Ditto on the Sharkbite! A little high priced, but very,very sweet.
45Andy
