Pipe Rattling when Diswasher running
markledbury | Posted in General Discussion on January 5, 2005 11:04am
While the dishwasher is running, I occasionally get severe rattling of the water pipes.  If I turn on the hot water at the sink next to the dishwasher ever so slightly, the rattling stops.  the House water pressure is about 60 psi.  It seems to have gotten worse over the last year or so.  Any ideas on how I can fix the rattling problem?
Thanks!!!
    IMERC | Jan 05, 2005 11:27pm | #1
    water seleniod on the DW is pulsating open to slightly open or rapid on and off...
    screen in the DW water inlet is pligged...
    supply line has a crimp in it...
    supply line is too small...
    The DW is starving fer water..
    the water in the main feed / supply is being pulsed..
    WOW!!!   What a Ride!
  2. hammer | Jan 06, 2005 02:21am | #2
    I would agree with IMERG. Since it's getting worse I would think a bad DW solenoid or a supply screen getting more clogged over time. Do you have a water softner? Could be calcium build up.
    Not sure but isn't 60 psi a tad high?
      IMERC | Jan 06, 2005 03:39am | #5
      60 isn't high...
      WOW!!!   What a Ride!
    goldhiller | Jan 06, 2005 02:31am | #3
    I'm with IMERC,too.
    Sounds like pulsating water hammer that's being relieved when you open that other faucet.
  4. DanH | Jan 06, 2005 03:25am | #4
    Install a hammer arrester on the HW pipe under the sink.
      IMERC | Jan 06, 2005 03:40am | #6
      why not fix the problem 1st or is the HA in addition to????
      WOW!!!   What a Ride!
      1. DanH | Jan 06, 2005 06:35am | #7
        Well, the hammer arrester is quick, easy, and will almost certainly fix the problem. Otherwise you're playing Easter egg hunt.
          IMERC | Jan 07, 2005 12:52am | #8
          ya but there is a deeper under lying problem that needs to be addressed...
          WOW!!!   What a Ride!
        2. UncleDunc | Jan 07, 2005 01:28am | #9
          That's like fixing the rattle in my truck engine by turning up the radio.
