Our plazma is wall mounted with the power cord running down the wall.
want to put in an ac outlet behind the TV so can’t see the power cord.
currently use a 6 outlet surge protector.
If an ac receptacle is put in behind the TV, what can I do for surge protection?
TIA
bobl Volo, non valeo
“But when you’re a kibbutzer and have no responsibility to decide the facts and apply the law, you can reach any conclusion you want because it doesn’t matter.” SHG
What I did was to run a length of conduit in the wall from behind the TV down to near the baseboard. TV cord goes down that & is out of sight. You can plug it into the supressor at floor level that way, and never see the cord.
Mike Hennessy
Pittsburgh, PA
I put a cable race from the base to behind the plasma (50" Sony) so I could run all the wires through it. Built a rolling cab to contain all of the electronics along with the surge protector. They're not really very big. You could do a recess under the mount. Here's a pic.
You can get receptacles with the surge protection built in. Here's one example. http://www.smarthome.com/865130.html
Pick up a breaker with surge protection on it for your panel....
like Stuart mentioned, or just search for" TVSS receptacles ", Hubbell makes some but the catalog URL is a foot long.
edit:
but the only problem I have with hiding it is not being able to see the device indication that tells you if it's working or if you have lost protection
Edited 3/24/2008 5:25 pm by maddog3
This is one of the items we use
http://www.panamax.com/Products/In-Wall/MIW-POWER-PRO.aspx
But we always tell the customer they should have a whole-house surge protector 1st when we do an A/V install to try and stop it before it gets to the components.
http://www.intermatic.com/Default.asp?action=subcat&sid=138&cid=61&did=6
When the install is done after the house is drywalled we use
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?sitex=10024:22372:US&item=12281
with a Leviton surge receptacle, the advantage of the REB is we have more room to snake the wires and we can tuck the A/V cables out of the way. It also works great when someone wants to add a plasma above an existing gas fireplace, we can cut a big enough hole to make sure the wires do not contact the fireplace/flue pipe.
http://www.issalarms.com
very nice, clean looking maybe you recall a company a few years back that was based in Batavia, Ill. that had developed a surge protector that could finally be used on the grounding wire in residential,
the claim was their device would protect against surges and if it failed would not cause a dead short to ground !
which was a problem with ordinary MOVs and the main reason they were never used in such an application I have looked several times since I read about it in EC&M and online, but have not found anything about them, I wondered if they were still around and if anyone ever used the devices.
Sorry, don't know who makes/made a surge like that.
oh well my quest continues.. :).
here's what i use
http://www.powerbridgesolution.com
hehehe a modern clock receptacle with an inny and an outty.
