my paint is peeling all the way down to the bare plaster in my 1912 home. the plaster appears to be unstained, very white and very soft, there seemes to be no water damage, what could be a cause and solution?
Structural steel and strong connections help a raised floor resist high winds and water.
Just my experience, but I haven't seen that happen on good plaster. I have seen it in an old building (with new plaster, by the way) that was a solid brick building with nothing between the plaster and the brick - the brick would wick moisture up the wall and it would cause the paint to fail - followed by the plaster flaking off. What is under the plaster?
Sounds like a moisture problem to me....
Greg
thanks...that seems to be the only reasonable cause, as i'm sure they knew how to make a plaster mix back then. there was vinyl wallpaper over many layers of paint, so perhaps moisture got back there and could not escape therefore causing the plaster to effloresce on a subtle scale.
You may have calcumine(sp?) a thin layer (thickness of a dime)of a special plaster put on walls or more comonly ceilings. It was made to deliberetly shed paint. That way you could start from scratch with a smooth wall.
yeesh! that's scarey, when was that product in use, i haven't heard or read of it
Check out this link. Tons of other links if you go to google.
This folder is probably not the best place for your question. Probably Construction Techniques or General Discussion. Sure you will get some great advice. If reposting delete orig. Good luck!
So what's different in your house recently?
Original 90 year old paint just suddenly started falling off? After 90 years?
Joe H
Milk paint was used some time in the past.
