John, I recently used blue board and a two coat process on a home in south Texas.Cost of the board at the time was $5.50. The labor was the kicker.The plaster we used was a white scratch coat with a pigmented top coat at a labor cost of $ 4.00 sq. foot and material cost of $1.25. Turned out beautiful, customers loved it.My labor cost were for a crew I brought out of Austin. I dont know what area your in or what the cost comparison woul be in you area.
Has anyone evaluated the cost difference between doing lathe and regular plater vs. blueboard and hardcoat. I was thinking about the differnce now that the cost for 4x8 board is $7.50 per sheet plus the installation labor. Would the cost for metal lathe and a full plaster job be cost effective?
Looking for other opinions and comments....
- John
*The lath would be way more expensive! The blueboard is only up a buck or two a sheet -- pennies per sf. In materials alone, the lath job would cost more.
*Andrew,Thanks for the reply - I too think that the board with hardcoat would be cheeper - but I am not sure and was just thinking.....- John
*Do you have labor sf quotes for either? I'd like to hear what this works goes for. Incidentally, USG says their blueboard system can be used as a one- or two-coat system, the latter being tougher thanks to the scratch coat but also harder to trowel smooth. Be sure which you're pricing.
*John. As andrew suggests, get quotes from each trade. As an alternative to both you might consider FiberBond manufactured by Louisiana-Pacific. Fiberbond is layered with a central core of perlite between two layers of fiber-reinforced gypsum. One of fiberboard's advantages is no taping is necessary. tjhe finished FiberBond wall is much harder and more like a plastered wall. It is free of the settlement cracks typical of a plastered wall. I hjave a section on this product in my book,_Complete_Building_Construction, 4th edition published by Macmillan. GeneL.
*John, I recently used blue board and a two coat process on a home in south Texas.Cost of the board at the time was $5.50. The labor was the kicker.The plaster we used was a white scratch coat with a pigmented top coat at a labor cost of $ 4.00 sq. foot and material cost of $1.25. Turned out beautiful, customers loved it.My labor cost were for a crew I brought out of Austin. I dont know what area your in or what the cost comparison woul be in you area.
*Ouch! For me, at those prices, it would be DIY or Do-It-Never! But it is a heck of a lot of labor, and requires skill.As Damon points out, the white coat can be tinted, or even left natural white. Blueboard allows painting the next day; true plaster require 60 days or more to cure.
*Gene - I believe that USG bought the rights to this product from LP. It's a great product to use in schools - very abrasion resitant. It may also have improved acoustical isolation performance - haven't seen lab tests but seems promising. The schools I'm familiar with use the 5/8" fibre bond on both sides and fill teh cavity with k35 - basically a cellulose. They report very good acosutical separation.Still doesn't quite have the appearance of wet plaster or veneer systems though....
*Bill. Good hearing from you. Did you see my post on a new gyupsum board? GeneL.
