Please help: Solution to sagging jois…
| Posted in General Discussion on April 7, 2000 07:16am
Span of joist 25 ft. sagging probably to weight of garage door.
Any suggestions on a fix.
  1. Guest_ | Apr 02, 2000 10:19pm | #1
    Remove the garage door. Or add a beam mid-span.
    1. Guest_ | Apr 02, 2000 11:07pm | #2
      *sister another joist (or two) along side the sagging one. Or tie the mid span of the sagging joist to the peak of the roof with a vertical 1x6.
      1. Guest_ | Apr 03, 2000 10:45pm | #3
        *You could build a temporary wall underneath to push it back up into place and then add a couple of stiff backs across the joist in the attic to hold them up. That should help.Ed. Williams
        1. Guest_ | Apr 07, 2000 07:16pm | #5
          *Well you're not very clear. Do you have one joist sagging ,or a few, or all? I just finished a retrofit and I installed a stiffback and pulled the c.j.s up to meet it with angle iron and some allthread. Anchored them in place with more angle and 1/2" lags. Pretty quick and painless.
  2. Peter_Geanopulos | Apr 07, 2000 07:16pm | #4
Use a Press Tool for Plumbing Connections
The Milwaukee M12 press tool has become a popular alternative to soldering copper for plumbing connections.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
