I am building a new house, and was planning to use CPVC for the water lines with a brass dropear 90 screwed to the framing to screw all my nipples into. I have seen some builders using this blue and red tubing with crimp fittings. What is it, and is it any good? Pro’s and cons to either system?
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
I am building a new house, and was planning to use CPVC for the water lines with a brass dropear 90 screwed to the framing to screw all my nipples into. I have seen some builders using this blue and red tubing with crimp fittings. What is it, and is it any good? Pro's and cons to either system?
