Plumbing a whirlpool bath faucet
| Posted in General Discussion on November 28, 2000 01:57am
I have located a faucet on the back side of a new whirlpool tub and I need 3/4 ” supply lines that are approximately 6 feet long. The connection must be made before the tub is lowered into the frame. I thought of using soft copper with compression fittings but I think they will bind when I go to lower the tub and the lines don’t flex. Does anyone know if there is 3/4′ flexible supply lines that can be made to length? Any suggestions?
  1. Greg_Schwien | Nov 28, 2000 01:57am | #1
    I have located a faucet on the back side of a new whirlpool tub and I need 3/4 " supply lines that are approximately 6 feet long. The connection must be made before the tub is lowered into the frame. I thought of using soft copper with compression fittings but I think they will bind when I go to lower the tub and the lines don't flex. Does anyone know if there is 3/4' flexible supply lines that can be made to length? Any suggestions?
