Plumbing question
msw | Posted in General Discussion on June 21, 2008 11:52am
I have a tee for the air uptake and a elbow coming out to the laundry sink after the tee for the air uptake.
If I move the elbow after the air uptake tee making the distance of approx. 5 inches to 7 inches, will this make a difference or does the air uptake have to be before the elbow for laundry sink.
I live in Howard county maryland, will this be within CODE.
    shelternerd | Jun 22, 2008 12:09am | #1
    got a picture?
  2. k1c | Jun 24, 2008 07:13pm | #2
    I am not a plumber but I'll take a deep breath and try to answer your question.  First I'll assume your laundry sink is in basement and your "air uptake" is vent.  The vent is either 3 or 4" pipe if it is used as drain from upstairs.  If it is smaller pipe, then it is probably for vent only.  Now, the sink has a trap and it leads directly to the vent/drain (called a stack).  If the stack is far enough away from the sink, a separate vent for the sink may have been installed.  This vent line will be above the sink drain pipe tied to the stack.  I plumbed mine this way, although the stack was not that far from the sink.  If you eliminate the vent, the sink may have drain problem and have problem keeping the water in the trap, to keep out the sewer gas.  If you are moving the sink, you can cut out the vent pipe in the same length as the drain pipe and reattach them using hubless connectors.  Get a plumbing book from a library and look at the diagram of drains and vents and how they work together, and that probably answer your question directly.  Hope this helps.
Kimberley Robles, Decorative Concrete
In this interview, Kimberley talks about the importance of proper training, current concrete trends in the Bay Area, and the history of racist housing policy in San Francisco.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
