Plumbing vent caps
jim12 | Posted in General Discussion on September 23, 2005 06:27am
to all,
I seem to remember seeing a recent review/article about attic plumbing vent caps that can now be used. Did I see it in FHB, or was I dreaming? If in FHB what issue was it? I started looking in recent issues, but thought I would try here.
thanks,
jim
  1. BobKovacs | Sep 23, 2005 06:43pm | #1
    It's in the new issue of FHB- they're called Air Admittance Valves.
    Bob
    1. jim12 | Sep 23, 2005 09:03pm | #2
      thanks Bob
        Soultrain | Sep 23, 2005 09:18pm | #3
        The AAV's weren't for attics, they were for places like kitchen islands & such where traditional venting is difficult.
        The article stated that in order for them to work proplerly, it still needed to connect to a vented DVW line.
        BossHog | Sep 23, 2005 09:22pm | #4
        Not everyplace in the country allows them to be used, so check your local codes.
        A leader in the Democratic Party is a boss, in the Republican Party he is a leader. [Harry Truman]
          Sailfish | Sep 23, 2005 09:25pm | #5
          Are they similiar to studor (sp) valve?-----------------------------------------------------------------------------
          WWPD
            BossHog | Sep 23, 2005 09:36pm | #6
            I assmed he was talking about studor vents. If not, I have no idea what else he might be referring to.
            Do medics in Rome refer to IVs as 4s?
            BillHartmann | Sep 23, 2005 11:27pm | #8
            Studor is a brand name.Air admitance valve is the generic name for that like of product.
        2. Brian | Sep 25, 2005 02:10am | #9
          Our inspector allow them for special cases - island sinks, log houses and such - otherwise they are a no no.  Why?  I guess some are unreliable?
           Treat every person you meet like you will know them the rest of your life - you just might!
  2. plumbbill | Sep 23, 2005 11:16pm | #7
    First check local codes is a start. Second no matter what you still need a vent to atmosphere that is equal in cross sectional area to the drain going out. These air admittance caps ie studor vents are a mechanical check vale and all mechanical things eventually fail. I am opposed to them but I have installed them when no other way was practical. Main problem is they let air in ( to keep traps from siphoning) but they don't let air out so pressure gain is possible and in extreme conditions you have what is called the boiling toilet effect, which is gases coming through the trap not a "big" deal but is a nuisance.
  3. Grizzly | Sep 25, 2005 07:23pm | #10
    Jim in my estimation they are a quick fix or for very special location. Beward what up the drain line. I installed one under our sink on a quick reno but I have a laundry washer up the line...everytime it drains the sink boils. I'm doing the walls shortly in the kitchen and will be putting a correct through-the-roof vent when that happens.
    Byron
    1. rasconc | Sep 27, 2005 03:13am | #11
      I have a similar problem, my sink burps.  I put a check valve just upstream of the laundry wye.  I believe it is just surface tension/friction with the laundry foam discharge and does not really hurt anything.  There is never any sewer gas problem and the trap at the sink never empties.  I have thought about changing the sink trap to 2".  There is a 2" vent from the laundry to the main stack which is about twenty feet downstream of the sink with the aav (Studor brand) .
      I had a house in Georgia that had a similar long run from the laundry but it was cast iron instead of PVC.  I was concerned that I had a problem when I saw soapsuds on the roof, checked the line and no restrictions.
      Edited 9/26/2005 8:13 pm ET by rasconc
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
