plywood beadboard instead of drywall
dockelly | Posted in General Discussion on July 11, 2006 03:59am
Hi All,
I am about to close in my kitchen at our second home. It’s a 125 yr old cottage. I had to do some plumbing and electric work prior. Thinking of putting up 15/32 plywood beadboard instead of sheetrock. The look would fit in nicely with the rest of the house. I figure it would save me all the spackling, only to cover with beadboard paneling anyway. Can anyone think of the cons to this idea?
Kevin
  1. dirtysanchez | Jul 11, 2006 04:24am | #1
    bump
  2. RonH1 | Jul 11, 2006 05:05am | #2
    Hi Kevin:
    You might want to check local or state fire / building codes. They might specify a nonflamable wall covering, especially around the stove or any heat generating appliance. Personally, I like beadboard a lot, however, I've only used the 1/4" panelling.
    Good luck.
    Cheers:
    Ron.
    1. KirkG | Jul 11, 2006 05:43am | #3
      Definately check codes as drywall is probably mandated behind the paneling, both for fire code and energy savings.It also gives you a smoother surface to attach the paneling to.
Electric House Made With Cross-Laminated Timber
Integrating cross-laminated timber, wood-fiber insulation, panelized construction, and a solar-tile roof for Passive-House performance.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
