Pop Up Range Vent
Jemcon | Posted in General Discussion on March 13, 2007 02:17am
A customer today ask me to install a pop up range vent. It’s a filtered type of down draft hood.
I have never installed one but it doesn’t look to bad. Does anybody have a standard rough price? How about any tips on installing one of these?  Thanks Jeremy
Headstrong, I’ll take on anyone!
    EricPaulson | Mar 13, 2007 02:55am | #1
    I'll help...........you need to know where it is going to vent to. Down through the floor and out through a rim joist.
    Factors to consider are countertop material, electrical supply, distance and accesibility to area benaeth floor where duct will run, others I may have missed including brand and ease of install in general.
    I'd figure a good two days by the time you meet to look/talk/scratch your head and make all the runs to pick up duct work and.................maybe less, but you want to make money right?
    [email protected]
    WHICH content will be free, of course; WHICH content will require registration; but WHICH content will be available only to members of FineHomebuilding.com.???
    1. Jemcon | Mar 13, 2007 03:03am | #2
      Thanks.
      I know it's a carbon filter. She said it doesn't vent to the out side. She had  me close up 3 vents outside and doesn't want any holes outside. Electric is easy. There is access to the basement under the cabinet. I'll install a surface mount box.
      The counter is made of formica so it's easy cutting.
      Headstrong, I'll take on anyone!
        EricPaulson | Mar 13, 2007 03:24am | #3
        Never heard of such a thing.
        Down draft usually goes down through the cabinet either into a joist bay or below them and then to the exterior.
        Can't imagine a non venting pop up down draft working very well. Many of the venting one do not suck very well.
        Sounds like a HD sale.[email protected]
      2. dovetail97128 | Mar 13, 2007 04:03am | #4
        Couple of things.
        They are ugly (or at least the ones I installed ) from the back side when up in operating position. So I ended up having to build a high counter back to hide the stupid thing when operating to please the HO.
        The ones I installed took a deeper than normal cabinet to accomodate them and like Eric said downdrafted then vented out thru a rim joist.
        Unfinished basement helps a lot,.
        If it is a "recycler" with no vent to the outside HO may as well just open a window because that will be more effective and save money .
          EricPaulson | Mar 13, 2007 05:03am | #5
          Emphasis.[email protected]
          1. Jemcon | Mar 13, 2007 05:21am | #6
            I didn't buy it. Shes had it for a few months and needs it installed. I see it tomorow.
    txlandlord | Mar 13, 2007 05:26am | #7
    Maybe not an answer to your question, but:
    See attached.
    Kitchen Aid KIRD861HSS / 36" Telescoping Downdraft Unit / Builder Price Houston $599.99
    We are installing with a Kitchen Aid Cooktop.
    We have installed these in three custom home projects.
    Edited 3/12/2007 10:28 pm ET by txlandlord
