I read the article last month and was wondering if it is really cheaper to do prepainted hardi or not I have 2300 sq ft house. My buddies tell me the best results is to one coat of each. Which i figure is going to cost the most. I am just starting to get bids now. Has anyone just done prepainted how does it look and how well does the chalk match up and finally is really that much cheaper…
thanks
Prepainted looks good, but it doesn't look like painted.
It comes with color-match caulking and some touchup paint for face-nailed spots, field joints, and scuffs/scratches, and that stuff is definitely time consuming to work with and the color match isn't always bang-on. Also, at least in this area I can't get trim boards pre-finished, only the siding itself, so I wind up doing a certain amount of painting anyway for corners, wdws&drs trim, and so on.
All that said, it is a nice finish on the siding, seems to weather well, and I can go start to finish in one scaffolding setup per side of the house, which is a plus for me. With a bit of careful detailing during the install, which not all siding guys are used to, it turns out looking really sharp, but in a different way.
J
I just finished my own house using prepainted Hardi. Came out looking great. The caulk is a perfect match. Minimal touch up was needed but it does have a different sheen (on one 10'X10' area however one painter got carried away and touched up "everything" but that really can't be seen unless the light hits it just right, or wrong if you will). Be careful to have the siding guys not marr the finish when they cut or shear the pieces. As another poster said, they have to be careful.
Here's some close up photos.
Runnerguy
Runnerguy, do you just calk the inside corners?
We caulked everywhere the Hardi hit the Azek trim. Inside corners, outside corners, openings and where the topmost piece of hardi hit the fascia.Doug
The photo looked like on the inside corner - there is no trim, or maybe it is just very thin?
Oh ok, I understand. On the inside corner I used the Azek 5/4 picket profile. Same thickness as the other Azek 5/4 trim so it matched up but without having to rip a standard piece down.Runnerguy
Thanks, I will be using the 5/4 Hardie trim, but thought maybe I could get away without it.
Do you have a reference/website for color-matched caulk? (I've got the Weiss "Jungle Palm" color).Thanks,Scott.Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
Scott: Not really sure what you are referring to. I used one of the standard Hardi colors (Navajo Beige) and the caulk and touch up kits where sold at the same place I bought the Hardi (Southern Pacific).
Runnerguy
Sorry, I'm clearly out of touch here, probably because I bought the siding a year ago (it's sat in storage) and am only now installing it. I bought Hardi FC lap siding with Weiss factory applied coating in the "Jungle Palm" color. Is there an Internet-order supplier of color-match caulk?Thanks,Scott.Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
No. I really don't.
To bojangles: Never heard of the caulk changing color. A house I did 5 years ago the caulk is still exactly the same color as the siding. Looks great.
Runnerguy
We recently did a one car garage with hardi, and had to special order the non painted boards. The lumber yard carried several colors, but no primed.
The price difference was silly little $ so I would wonder why someone would not used the prepainted.
Plus it will buy you some time if you don't feel like putting a good topcoat on right away.
[email protected]
My 2 cents worth....I would never install prepainted cement board siding. Caulk will eventually turn a different color than the siding, get moldy, nail heads that show should be painted etc. etc.
Buy good paint, caulk, paint the siding, trim and caulk with two coats and you will have a professional looking job that will last a long time.
Nothing is easier to paint than cement siding.
