I’m planning on repainting my house this spring,
and was wondering if pressure washing the peeling
paint would do more harm than good.
If pressure washing would be worth while, would
i have to follow it with a sander?
These personalized workspaces were designed to fit the unique needs and projects of their makers.
Very very bad idea, for a lot of reasons.
First of all, pressure washers will shread the wood of your
siding or trim. Sure some loose paint will fly off but so
will the softer part of the wood grain. I have been trying
to restore an old farm house that was pressure shreaded. You
can easily trace every movement of the wand.
Secondly, you will be injecting a lot of water into the
wood. The chief reason that paint fails is because of
mosture inside the wood. New paint will not adhere if there
is water trying to gas out. It will be pushed off.
Thirdly, the pressure of the jetstream will find cracks in
the siding or seams around windows and it will infiltrate at
a tremendous rate. Any insulation which has been lovingly
placed will be wadded and shoved out of the way not to
mention left to soak for weeks. Hello mold and mildew.
Finally, there is no decent way to collect the shreads of
paint (probably lead) after they have been launched by water
pressure measured in 4 digets.
I know it seems tedious to remove it any other way but trust
me it, pressure washing is not the way to go. Save it for
stripping gunk off of your e
I have to agree. As a professional painter (amongst other thins) I can tell you from a pro's standpoint - DON'T DO IT
Stripping paint with a pressure washer is nothing more than a bad shortcut. Ditto on all the resons stated above about water penetration, wood shredding, etc...
Look at ads for pressure washers. They will never show you someone stripping paint off of old houses with their product. They know better.
Proper prep work is tedious, slow, and painstaking. As much as everyone hates to do it, it is a must if you want a proper, long lasting paint job.
As for the question about sanding AFTER pressure washing, the answer is most definitely yes. You will have to sand because the wood will fuzz up. Then you'll probably have to scrape the loose paint that comes loose a day or two AFTER you pressure washed anyway.
Been there, done that...
James DuHamel
Thanks for the advice guys you saved me a mess.
I'm planning on repainting my house this spring,
