Prevent trapped moisture in a Basement
I have an unfinished walkout basement. I was reading of the 1 in. EPS with (2) 1/2 in. plywood floor as a breathable barrier floor. Has anyone done this? How do I compensate for a 2 inch rise to the floor at the existing back door? The back wall and center support wall are stud construction. Do I have to add 2×4 to attach the bottom of the sheetrock
As I understand the Q - you would need to reframe and re-install the door 2" higher. I don't understand the last part of what you say about bottom of sheetrock....
OOps - FLASH! I get it - you are wondering at bottom plate on teh walls. I was thinking SR ceiling.
nothing extra needed there
