Problems with Paint
tiarahi | Posted in General Discussion on April 21, 2006 05:13am
I’m painting some luan doors in my house. It looks like the previous owner stained them a dark brown. It dosen’t appear to have a clear coating. I tried painting it with water based enamel and it bled through PINK ! 3 coats of paint later still PINK ! 2 Coats of primer later STILL PINK ! Should I shellac or Polyurethane the remaining doors before painting? Can the pink door be saved?
        Thanks, tiarahi
  1. philarenewal | Apr 21, 2006 06:04am | #1
    Zinser BIN (heavy shellac)
    or original Kilz (I think it's lacquer based)
    Check the can directions to see which is compatible with what you are painting over (poly, varnish, lacquer, shellac, something else?).
    If the original surfaces are glossy, make sure to scuff them up with some fine sandpaper (220 grit should do the trick).
    "Let's get crack-a-lackin"  --- Adam Carolla
    1. Mooney | Apr 21, 2006 06:17am | #3
      oil.
      Tim
  2. Mooney | Apr 21, 2006 06:16am | #2
    A degreasing with super clean and a oil primer coat would have been clear sailing .
    You screwed the pooch with the latex. You deserve it . Read the cans next time at least.
    Tim
    1. DonCanDo | Apr 21, 2006 03:07pm | #5
      "screwed the pooch"?  Is this an expression?  It's not quite clicking for me.
      As for reading the cans... of course they always say that the surface to be painted should be clean and free of foreign materials, but sometimes it's hard to know whether or not the previous finish (if you even notice that it has one) will react with the paint or not.
      -Don
      1. Mooney | Apr 21, 2006 04:09pm | #6
        I can understand the first time and he even tried primer , but he tried latex primer. and kept coating it .
        "I'm painting some luan doors in my house. It looks like the previous owner stained them a dark brown. It dosen't appear to have a clear coating. I tried painting it with water based enamel and it bled through PINK ! 3 coats of paint later still PINK ! 2 Coats of primer later STILL PINK ! Should I shellac or Polyurethane the remaining doors before painting? Can the pink door be saved?"
        I guess we all have to get our experience.
        Tim
          razzman | Apr 21, 2006 05:01pm | #7
          Screwed the pooch.
          DonCanDo age is listed as 'over the next hill' but I've heard that expression all my life.
          Can't just be regional cause we're a thousand miles apart.
           seeyou invented screwing the pooch
          'Nemo me impune lacesset'No one will provoke me with impunity
          Edited 4/21/2006 10:13 am ET by razzman
          1. DonCanDo | Apr 22, 2006 12:58am | #8
            Actually, I never heard the expression "over the next hill" either.  It just sorta made sense as I was filling in my age.
            As for "screwed the pooch", I just finished googling it and sure enough, it's a common expression and makes perfect sense in the context it was used.
            So, you live, you learn, you repeat.
            -Don
            Sphere | Apr 22, 2006 02:10am | #9
            How many have you pooched? I'd strip the bad ones and SPRAY a coat of Zinnser's Seal-Cote. It is Shellac. Spraying will not 'pull' up the old finish as badly as brushing.
            Then you can put on whatever floats your boat.
            You gotta be kidding me ..Jorge is @ what %? Now?
            MarkH | Apr 22, 2006 02:29am | #10
            I'd just paint em pink and have a drink.
    IMERC | Apr 21, 2006 06:58am | #4
    yup..
    Kiltz or Bin 123 in oil base...
    WOW!!! What a Ride!
    1. Jemcon | Apr 22, 2006 05:02am | #11
      I've used 123 in latex with no problem. I've also used SW bond and seal, that works good too.
      Headstong, I'll take on anyone!
        IMERC | Apr 22, 2006 06:52am | #12
        each has it's place...
        oil base for this application....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
  4. bc | Apr 22, 2006 06:22pm | #13
    you are using a cheap paint. try #314 from benjamin moore (Satin Impervo Latex) Cheap paint doesnt dry as thick and with time the pink color will bleed through. You need something that dries thick and has a better grade of titanium dioxide so the color will "hold" with time....
    1. DonCanDo | Apr 23, 2006 12:49am | #14
      He already used 3 coats of paint and 2 coats of primer.  I don't think thickness is the issue.  Whatever stain is on the door is water-soluble and will bleed through ANY latex paint regardless of quality.
      -Don
        Sphere | Apr 23, 2006 02:48am | #15
        And isn't it Ti oxide, not Ti dioxide?  I forget most of my paint chemistry but dioxide just don't sound familiar.
        tagline comments are temporarily suspended due to Percostte
        1. philarenewal | Apr 23, 2006 02:55am | #16
          Hey Sphere,
          I'm pretty sure it is Titanium dioxide.  Seems a lot of references to it just call it titanium oxide, but it's actually titanium dioxide.
          Pretty sure anyway.
            Sphere | Apr 23, 2006 03:14am | #17
            I just think of hot female lifeguards with white noses at the shore when I hear those words.
          2. philarenewal | Apr 23, 2006 03:22am | #18
            Stroke, stroke . . . .
            Sphere | Apr 23, 2006 03:26am | #19
            Thats what I'm talkin about!  geeze, I ain't seen the ocean in 5 yrs.  Gotta fix that this yr.
          4. WayneL5 | Apr 23, 2006 05:02pm | #21
            You are right, definitely titanium dioxide, TiO2.
  5. tiarahi | Apr 23, 2006 06:11am | #20
    Thanks to everyone! You have given me some good ideas. The best was paint em pink and have a drink!.......Gotta stay away from this painting stuff !!
