Problems with Steam Heating (leaking?)
bonefish | Posted in Energy, Heating & Insulation on March 2, 2003 10:43am
All,
Two years ago we purchased a house that was originally built in 1740.  The house has an old steam system with a new burner that worked well last winter and continues to keep the house warm albeit with a higher oil bill.  Last fall we had the house repainted but did not change the color.  The house is yellow.  For the last few weeks we have had rusty colored moisture leaking through the clapboards on the outside of the house.  The moisture is concentrated in two areas but both are fairly large.  One section encompasses an entire wall on the outside of the house.
My first thought was that the steam system was leaking inside the walls and the steam was finding its way through the outside of the house but I continue to be perplexed.  There are no signs of moisture on the inside of the house.  Common sense tells me that if the pipes were leaking inside the walls it would be much easier for moisture to come through old plaster walls than find its way through clapboards and a new coat of primer and paint.  But the moisture looks like the rusty colored water from our steam system.  Another confusing aspect of this is that the rust colored stains appear in areas above where any heating pipes travel.  For example, the stains are seen on the outside of the house on the wall both above and below where a radiator is located.
Could steam be leaking through piping inside the walls, rising, condensing, and then finding its way through the walls and then dripping down the outside the house without causing any visible signs on the inside of the house?  Has anyone ever heard of this happening before?
It honestly looks like the house is bleeding.  One entire wall on the outside is just dripping with rust colored stains.  I had our heating company over to look at the situation and the technician said he had never seen anything like this.  He suggested we contact the painter to see if there could have been some reaction between the existing coat of paint and the new primer and paint.  Again, the house was originally yellow, the new primer was yellow and the new paint was yellow.  The only difference between the two paints was that the original was an oil base while the new paint is latex.  Could this somehow have an effect?
Another point of interest is that I accidentally overfilled the system with water a few weeks ago.  However, the rusty colored water on the outside of the house had been occurring prior to my overfilling the system with water although it did seem to get worse after overfilling the system.  After overfilling the system, I immediately shut down the boiler and called the heating company over.  They only emptied three buckets of water out of the system and told me that the water never even made it to the first floor.  (There are 2.5-inch steam pipes in the basement.  And, no water came out of any of the radiators.)
I would greatly appreciate any thoughts anyone might have?
Thanks,
Henry
  1. timkline | Mar 03, 2003 03:12am | #1
    Yes, your steam pipes could cause this. Is there any chance this could be an ice dam on the roof from snow and ice buildup ?  Your pipes are inside your exterior walls ? Are your pipes or walls insulated ?
    carpenter in transition
    1. bonefish | Mar 03, 2003 03:38am | #2
       I don't think there is an ice damn on the roof although the greatest incidence occurred just after the last big snow storm we had here in Massachusetts.  I suppose there could have been an ice damn.  Could that cause it?  How?  If you think this could be the cause of the problem, do you know how to reduce the chance of an ice damn forming in the future?
      The pipes are insulated in the basement with some fiberglass wrapping.  I don't know if they are insulated behind the walls.  Some areas of our house do have insulation but some areas have no insulation at all.  I think that there is a modest amount of insulation behind the walls where the staining is occurring.
      1. timkline | Mar 03, 2003 05:29am | #3
        This is the giveaway that it is an ice dam and not a steam problem. Normally, a steam leak would cause a leak in a concentrated area. I have had three of them in my house. I am betting this to be an ice dam. Is this happening on gable ends of your house ?  I would seriously doubt it. More than likely, it is happening only in the eaves where you have overhangs. The dirty water is coming through the roof into your house and back out again on your siding. I am not going to give you any more explanation on how this happens. You can read about it in the link below. It is one of the best links to ice dam causes and solutions. By the way, did you see water coming inside your window heads ?  Have you been up in your attic lately ? Is a lack of ventilation causing any mold growth up there ?  Check it out.
        http://www.extension.umn.edu/distribution/housingandclothing/DK1068.htmlcarpenter in transition
        1. bonefish | Mar 04, 2003 02:34pm | #4
          Dear Tim,
          Thank you for your comments and for the link to the article about ice dams.  After reviewing the article, I think you are absolutely correct.
          Thank you again for your help.
          Sincerely,
          Henry
Outdoor Lighting
