propane seems like its on a timer.
semisavant | Posted in Energy, Heating & Insulation on December 2, 2004 08:30am
Never had a problem with gas in home until temp started to drop. It’s almost like it’s on a timer. At 9pm the gas range will start and within 1 minute go out. Same with pilot for h2o heater. As the sun warms up the outside propane tank, all flows and pilots stay lit as well. The tank is at 65% and I don’t think the temps are significantly lower than normal (mid 20’s). I “tented” plywood over the 250 gal tank and all the 1/2 galvy is insulated. I have a new regulator and like I say during the day all is well…
Thanks in advance,
Steve
Edited 12/3/2004 2:52 pm ET by semi-savant
  1. bigfootnampa | Dec 02, 2004 10:30am | #1
    Your regulator may be freezing up.  Remember that as the propane decompresses going through the regulator it acts as a refrigerant.  Try heating the regulator during the problem phase and see if that is the problem.  Also think about moisture in the lines as another possibility.
      Sphere | Dec 04, 2004 03:44am | #6
      Moisture in the line is freezing ,crystalizing..disconnect it and blow it out. Esp. a a low spot bend.
  2. DaveRicheson | Dec 02, 2004 01:55pm | #2
    I addition to the moisture, look at the vents on the regulator(s).  You may find that some insect has built a home there over the summer. Causes enough restriction to be a problem durring cold weather/high floe periods. The vent, I think, provides the ambient pressure side of the regulator operation. It has to be open completely, or the the regulator doesn't see real ambient pressure durring high flow periods. It reduces the flow to match the pressure and drops below the low limit pressure setting and the gas shuts off.
    Dave
    semisavant | Dec 03, 2004 10:53pm | #3
    Thanks for responses! I checked the regulator screen and it appears unobstructed. How does one heat a regulator?
    Steve
    1. joeh | Dec 03, 2004 11:18pm | #4
      A hair drier to see if it solves the problem, a drop light with a small wattage bulb to keep it warm at night.
      Joe H
  4. MrBill | Dec 04, 2004 03:00am | #5
    Steve,
     I suggest that you call your gas supplier and have them come out and look at your tank. We had propane at the last building my business was in and we never had the problem you describe. The temperature dropped to those ranges regularly in the winter. Gas is not all that dangerous if you respect it, but I would not even dream of running a hair dryer or a light bulb near it without knowing what the problem is. The gas supplier will more than likely check it for no charge. They do not want or need dangerous setups.
    Be safe,
    Bill Koustenis
    Advanced Automotive Machine
    Waldorf Md
  5. DanH | Dec 04, 2004 04:32am | #7
    Yeah, you got moisture in there or something. When we first moved in here 28 years ago we couldn't get NG hookup, so had propane for a year. That year temps dipped to 30 below, but we never had a problem with the furnace.
    semisavant | Dec 09, 2004 10:12am | #8
    Thanks for all your input. I ended up shedding some incandesent light on the regulator and got resolution. No problems for a week....
    Steve
      IMERC | Dec 09, 2004 05:23pm | #9
      are you using only just one regulator at the tank with a direct hook up to the house or dual regulators??? One at/on the tank that's feeding to a regulator mounted in/at the line at the POE on the house....
      WOW!!!   What a Ride!
        semisavant | Dec 09, 2004 07:01pm | #10
        One regulator next to the tank.Steve
          IMERC | Dec 09, 2004 07:37pm | #11
          switch to a 2 regulator system...
          high pressure at the tank...
          low pressure control at the house...
          good to go at minus 40 below....
          and then some....
          WOW!!!   What a Ride!
            semisavant | Jan 16, 2005 03:03am | #12
            For what it's worth....
            Started having problems with the propane again. I d/c the lines and blew compressed air throughout and everything seems to be (finally) resolved!
            Steve
            Edited 1/15/2005 7:03 pm ET by semi-savant
