I was checking out some other forums (Housechat) recently and saw this. I thought we could be of service.
http://forums.taunton.com/tp-housechat/messages?msg=1174.1
Edited 2/5/2008 12:59 pm by JMadson
I'm not familar with radiators, but wouldn't placing a solid shelf over the beast cause problems with its heating function?
Radiator covers usually have a solid top, but vented in the front.http://www.customradiatorenclosures.com/http://www.empireradiatorcovers.com/emodels.htmlhttp://www.eradiatorcovers.com/http://www.beautifulradiators.com/
Yes it would, but the radiator that I want to build a shelving unit around is never in use. My apartment is situated very close to the building heating unit and its very hot in there. I never use this radiator. I only use the radiator in the kitchen and back bedroom, which have to be turned back off as soon as the temperature goes up outside above freezing.
So moisture from steam wouldn't be a problem. I don't want a purchased radiator cover, I want to build a shelving unit around it, including the wall space to the left of it. The MDF I purchased was too thin for the screws in the L-Bracket set I purchased to put it together. What do you think?
Rodezzy, Fiber Artist
Edited 2/5/2008 3:04 pm ET by rodezzy
MDF is not a good material to nail into.You need to screw into it..
