I have to bid a big job installing PVC railings on newly built condos for the decks. I cannot find a price for them in any of my books.
Does anyone out there do this work and have a LF price they can share? Labor only. The buildings are 3 story.
I am in the Richmond,VA metro area.
Any help would be appreciated.
*BUMP*
Plain PVC? Seems UV compromisable unless this is PVC coated steel as is used in Food Mfg plants for wiring. That stuff is 8 to 10 bucks a foot with 8 bucks at min per fitting.
If you have a bid spec type the details in a post here.
There is no way I'd use vinyl or PVC exposed to the elements as a safety rail unless there was something solid doing the retaining and the PVC was a cosmetic cover. Menards has the Cosmetic cover type of PVC or Vinyl. Theirs covers a 4x4 Wolmanized post.
Post the bid spec specifics.
They are a thick composite railing similar to the items sold at lowes. They are very strong. I am not supplying the product, just labor to install them.You fasten them to the brick/siding and make a run to a post set on a galvanized fastener and return to the other wall; forming an "L" shaped railing.
