Ok, I know it is a stupid question, but if I am gluing white PVC to black ABS, which type of glue should I use?
The way I learned it, dissimilar plastics are treated just like dissimilar materials, with a coupling, like a neoprene or the like.
I'm no chemistry whiz, but it would seem chemically difficult to solvent weld two different plastics together. Might could be there's an epoxy that works, though.
I could be wrong, too.
you can buy a glue to preform this task look at a plumbing wholesaler if you cannt find it at ace or h.d.
pvc to abs transition cement is what you are looking for
Thanks. I found a product at HD called "ALL PURPOSE CEMENT" for PVC, ABS, and CPVC. Will this suffice? This is for a waste connection, so pressure is not an issue.
Edited 3/24/2005 12:38 pm ET by NCLAQUER
No, All purpose is different. There is a specific transistion cememnt.I have seen it at Lowes.http://www.ipscorp.com/wo_html/multi.htmlhttp://www.herchem.com/products/pipecement.htmlhttp://www.elchem.com/solvents_chart.htm
ditto what Bill says ...
all purpose is junk.
Get the real stuff.
if I remember right ... toxic green color(maybe blue?) and real goopy. Looks like it'll kill ya.
That's how U know it'll work!
Buck Construction
Artistry in Carpentry
Pgh, PA
If possible, join two pieces of the different pipe with a fernco coupling/no hub coupling (rubber w/stainless band clamp). If not possible, get a can of the transition cement.
