We have a massive brick fireplace that we’d like to paint a light color, probably white. Since it is inside, we can’t think of a way to pressure wash or chemically clean and rinse the surface to prepare it to take the paint. We anticipate using Drylock for priming at this point. Can anyone recommend a prep procedure and primer/finish coat that will do the job without ruining the house? There is also some efflorescence to deal with. Thanks!!!
I am not sure how to best remove the flourescence with out making a mess inside the house. A mild acid, is what is generally used outside, I believe.
I use Kilz primer, and Gliddens on exterior brick, and the brick pretty much soaks up primer like a sponge. If you do this even half right, you will have no adhesion problems, until you decide you would like to remove the paint.
rkintz: Have you tried washing it with TSP (aka Spic and Span)? You have to wear gloves or it will really irritate your skin. If you are going to use the fireplace, don't paint it white!
mimi
I'm going to post my uninivited opinion on painting brick. Please please please please don't do it. I'm sure you have a valid reason, such as an overpowering fireplace that darkens the room too much. Brick is so beautiful, it deserves to be highlighted. In most places it is considered a sought after feature. It has a warmth in its character that will be lost if it is painted. Not to mention, someone a few years down the road, either you or the next homeowner will curse loudly and interminably as they try to strip off the paint and return it to its natural intended form. I beg you to reconsider, finding another solution to whatever your goal is. Proper lighting, sculpture. Consult a designer who i am sure can suggest another option. THanks for listening and do what you think is best
Edited 6/30/2005 11:47 am ET by NeilPuck
