questions for the pool guys
chillywilly | Posted in General Discussion on August 12, 2004 05:38am
DW and I are looking to buy a house that had an ingound pool which was filled in.  We would like to have a pool put back into the same spot.  what questions should I be asking to make sure this is doable within reason?
  1. dIrishInMe | Aug 15, 2004 02:30am | #1
    I'm not a pool guy, but do have one, and managed the construction of it.  I'm thinking you should find out the dimensions of the old pool - L , W & D and plan on building one that is at least that big.  Pools are pretty much like footers in that you want to set them on solid (preferably unexcavated) ground.  So, for example, if there was a 10' deep pool there and you want a 6' deep pool, it may not work out too well.  Also, you may want to find out what type the old pool was and how it was filled in.  If, for example, there is 20 tons of gunnite pushed down in the bottom of the hole, and then another 20 tons of old concrete pool deck, it will effect the cost of construction of the new pool.  Just a few random thoughts.
    Matt
  2. DougU | Aug 15, 2004 02:58am | #2
    I know less about pools than I do about space shuttles to the moon but, the company that I worked for had to fill in two pools at an apartment complex, we jackhammered I think about 30% of the bottom up and filled it in with dirt.
    If they followed that then you are going to have a mess to clean up first!
    RichColumbus | Aug 15, 2004 07:28am | #3
    I would first find out what kind of mess is there from the old pool... as has been suggested.  The costs of digging out a mess can be rather costly.
    Then, I would probably have some core samples drilled in the old pool's location.  This will give you an idea of what is below.  Just perhaps maybe... there was a reason the old pool was filled in.  If you find out what is beneath the old pool... you may find something good... or you may find something that would be prohibitive of a pool being in that location (maybe the reason the old pool was fulled in).  A little investment now may save a lot of $$ in the future if you buy the place.
    I will also agree that the new pool will probably have to be bigger and deeper than the old pool was.  I know I wouldn't want a pool built on top of (probably) uncompacted fill.  If you cannot find out exactly how big and deep th pool was... maybe schedule a few more core samples along the perceived perimeter.
    BTW.. I am not a pool guy either... just some semi-edumicated guesses.
    Edited 8/15/2004 12:29 am ET by Rich from Columbus
Mortar for Old Masonry
