quick tile grout help please
| Posted in General Discussion on May 19, 2000 04:54am
i have to grout a stone (my own) floor and have laticrete wall grout – will this “wall grout” work well for a floor? i want to do it right but its a 2 1/2 hour round trip to the supplier. i want to do this monday morning and just now discovered we have “wall grout” instead of “floor grout”. what is the difference anyway?
many thanks for any help.
john
  1. Guest_ | May 15, 2000 04:07am | #1
    John, The wall grout probably doesn't contain sand and is good for filling cracks up to 1/8". The floor grout contains sand and is used to fill the larger spaces between floor tile. If you use non-sanded grout in a large space , it will shrink and crack.
    1. Guest_ | May 15, 2000 04:55am | #2
      *thanks for your quick reply. the floor also has 1/16" joints. sounds like it should work then?thanksjohn
      1. Guest_ | May 15, 2000 06:39am | #3
        *Don't have a clue what wall grout is.Standard grout is either sanded or unsanded. Sanded for gaps over 1/16th; unsanded for 1/16th or less.
        1. Guest_ | May 15, 2000 02:15pm | #4
          *YUP!
          1. Guest_ | May 16, 2000 07:43am | #5
            *Uhh.... Excuse me a minute Scooter..."Standard grout is either sanded or unsanded. Sanded for gaps over 1/16th; unsanded for 1/16th or less."That should read 1/4", not 1/16".Just a thought...James DuHamel
          2. Guest_ | May 16, 2000 08:21am | #6
            *thanks guys - got it down - looks good.
          3. Guest_ | May 18, 2000 04:59am | #7
            *Uh, James....1/8" or less for unsanded buddy. I use sanded grout in all my joints 1/8" or larger.Dave
          4. Guest_ | May 19, 2000 04:54am | #8
            *No no no no no!!!!!!Only use the unsanded grout in joints 1/32 or smaller, or if on wall tile laid diagonal with joints over 7/8ths. Sanded grout should only then be used when you have nothing greener to put into your joints. Of course the sanded grout does work better if used upsidedown with the left hand on a ceiling with a 7% pitch. Now I always perfer unsanded with a little sugar as a substitute for non-dairy creamer. Although some people contend that it could cause constipation. Maybe half sanded and half unsanded would loosen one back up.I'm sorry John, I just couldn't resist.Scott
A Practical Perfect Wall
  • The New Old Colonial
