Quikrete sealing as a curing agent?
jonblakemore | Posted in Construction Techniques on August 31, 2009 10:18am
Would you use this Quikrete Concrete Sealer (no. 8800) to facilitate curing of a slab?
Anybody have something better they like?
Jon Blakemore
RappahannockINC.com
Fredericksburg, VA
  1. 6bag | Sep 01, 2009 03:32am | #1
    i would stay away from anything that has "Quikrete" on it, unless your doing post holes for a mail box, or fence.  what kind of slab are you trying to cure, what kind of concrete do you plane on using, what are the weather conditions?  alot goes into picking a curing process.
      jonblakemore | Sep 01, 2009 05:08am | #2
      24'x24' garage slab. Weather should be cool (starting in about 3 weeks).
      1. whitedogstr8leg | Sep 01, 2009 08:08am | #3
         Go to your local concrete plant and ask them what THEY use for a sealer.   Some sealers can be just sprayed on, others will need to be "brushed on"  using a large, close-napped paint roller.  " Although I have the right to remain stupid, I try not to abuse that right"
      2. 6bag | Sep 01, 2009 03:53pm | #4
        i wouldn't use any sealer at all.  i would just keep the slap moist for 3 day.  you can use a lawn sprinkler, that seems to work best.  water based sealer are a waste of money, they wash off and don't last long.  keeping the slab wet for a few days does the same thing as a water based sealer.
        if your trying to protect the slab, you can use a acrylic sealer.  this will last much longer then a water based sealer.  i don't like to used acrylic sealer as a curing compound because they can make the concrete look blotchy.  with they acrylic sealer i wait as long as i can before aplying.
Drafting the 2027 IRC
  • The New Old Colonial
