R factor insulation
Malades | Posted in General Discussion on May 7, 2008 11:01am
2″ x 6″ construction in a Maine cabin but Owens Corning insulation R-19 is 6 1/4″ thick. Crushing it down to 5 1/2″ looses 1 R factor.  R-21 is made for 2 x 6 with a 5 1/2″ thickness but you can’t find R-21 anywhere.
How can 5 1/2″ = R-21    while 6 1/4″ = R-19 ? Does the loss of 3 R factors mean that much. I would think that every R factor I can gain for my Maine property is going to be worth it.
Thanks,
Chuck
  1. DanH | May 07, 2008 11:15pm | #1
    R you sure you want to open this can of worms?
    R factor is important, but not nearly as important as getting a tight envelope. Obsess on sealing air leaks and don't worry quite so much about R factor.
    (Expect any minute to be told that you're a fool to use fiberglass instead of 1) cellulose, 2) sprayed foam, 3) rigid foam on the outside, 4) ICFs, or 5) SIPs. And I'm sure I left out a few.)
    What is wanted is not the will to believe, but the will to find out, which is the exact opposite. --Bertrand Russell
    1. Malades | May 07, 2008 11:37pm | #2
      Thanks Dan,
      I guess I will be expecting a "fool" comment soon, as I do plan on using fiberglass. The cabin is totally wrapped and taped. Foamed around all doors and windows. Insulated and wrapped under the cabin. Ridge vented with R-38 in the cathedral ceilings.
      I am a legalized booky and with my 2 college sons (architectural design and computer science) we are building ourselves (with A LOT of help from various sources). 4 years into it now and 37 miles away from the closest lumber/outlet store so we carry in as much as we can each trip.
      Thanks again
      Chuck
    shelternerd | May 08, 2008 02:47am | #3
    I think it's worth ordering the R-21 batts
    but I can't answer the question as to why R-21 "high density" performs better than 6" R-19 squashed down to 5 1/2"
    And I really don't understand why R-19 in a open sided floor assembly performs at R-18 if fit snugly into a 5 1/2" wall cavity that's air sealed on all sides.
