Radiant Floor Heating For A Shop
byoung0454 | Posted in General Discussion on September 30, 2006 04:56am
I am going to start framing my shop this weekend, a 40×80 pole barn 30×40 of it will not be heated. I am wanting to heat it with radiant heat with my heat being from a wood boiler. I plan on taking this job on myself and I am looking for any help I can get on this.
Also I am going to have the floor poured 5″ thick, my concrete contractor I use on a regular bases said to go with the 5″ pour since I will have some heavy machinery setting on it. Will this affect the heat transfer in any way?
  1. donpapenburg | Sep 30, 2006 06:07am | #1
    Make sure you put the heat tubes in the unheated part with its own zone . then when you expand your shop it will have heat also.    The floor will be warm under the machines that you park in there .Not like tube heaters on the ceiling .  so it will not realy affect the heat transfer.
  2. nailbanger | Sep 30, 2006 02:28pm | #2
    I agree with Don, Put the tubing in the floor of the unheated space too. You just may not use it now but it'll be there when you eventually want it. As to the 5" pour, I would think that as long as you have insulation under the slab and the tubing is centered in the slab, it should work fine. It'll probably take longer to heat up the additional mass but it'll also take longer to cool it off when you raise the doors to bring in that heavy equipment.  Also, if you have two zones, you wouldn't have to keep both sides at the same temp. You could keep the equipment bay slightly above freezing and still keep your shop space nice & toasty.
    BILL
  3. daveinnh | Oct 01, 2006 04:48pm | #3
    My basement workshop has radiant heat.  Our builder:
    • graded and compacted subgrade
    • placed poly so moisture in soil doesn't migrate up thru slab
    • installed 2" foamboard insulation above that
    • configured tubing
    • poured slab
    Exterior perimeter drains are wrapped in a gravel & geotextile envelope too.
    We only have one zone in the basement.  I'd consider more - just have the plumber check the manifold capacity.  Also, it sure helps to have valves in each zone to release air.  Price of saving $ for valves isn't worth the trouble.
  4. NRTRob | Oct 02, 2006 12:56am | #4
    are you going to keep the shop heated consistently? that's a lot of mass. You won't like it if you are planning on turning up the heat just before you go work in the shop..
    -=Northeast Radiant Technology=-
    Radiant Design, Consultation, Parts Supply
    http://www.NRTradiant.com
    1. byoung0454 | Oct 02, 2006 03:33am | #6
      yes it will, I plan on setting the temp at the slab to about 65
    2. nailbanger | Oct 02, 2006 04:14am | #7
      I thought that the whole point of radiant heat was not to turn it up and down a lot. I thought that the idea was to take advantage of the mass so that it was more economical and so the temp stayed even. Am I wrong here?
      BILL
      1. plumbbill | Oct 02, 2006 06:45am | #8
        You are not wrong.
        Radiant is slow to heat & slow to cool."Guns don't kill people----- Husbands that come home early do." Larry the cable guy
      2. NRTRob | Oct 02, 2006 04:49pm | #9
        You are correct. However, that's not how a lot of people want to run the heat in their shops which are often "periodic use" areas, and I just wanted to make sure he understood that it should be run consistently.-------------------------------------
  5. SteveFFF | Oct 02, 2006 03:26am | #5
    I did my shop like Daveinnh shows. You should pressure test the system before the pour and then leave it pressurized when the concrete goes down. I didn't have the manifold in time but got lucky with a crew that was careful with their tools.
    Steve.
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
