radiant heat subflooring panels
cic317 | Posted in General Discussion on September 25, 2005 05:05am
intrested in installing radiant heat w/ solid oak flooring. Has anyone tried the subflooring w/grooves for the tubing. I have existing uninsulated slab on grade & had planned to build up the floor w/ 2x sleepers w/ 1/2″ ridgid insulation in between,then lay the pex tubing, cover the area w/ clean sand for mass & lay 3/4″ T&G ply. finally install 3/4″x2 1/4″ quarter sawn white oak.
Any input would help.
  1. stinger | Sep 25, 2005 05:52am | #1
    Look for the Wirsbo product that is in composite wood panels, with aluminum-lined tube tracks.  It is the high-end product used in all the really big ticket homes here.
    If your slab is level, consider gluing down CDX in 2x8 bricklaid strips.  Bostik makes a great glue for the job, a moisture-curing urethane.  Then screw on the Wirsbo panels, do the tubing, and subfloor.
    The beauty is that you can see right where your tubing is when you are flooring atop it, so you won't get any nail punctures.
    1. cic317 | Sep 26, 2005 01:58am | #2
      thanks for the info, you mentioned 2x8 ply rips,any reason no to go w/ full sheets?
      1. stinger | Sep 26, 2005 02:19am | #3
        You want some flexibility in the ply that you will glue down, and ripping the sheets in half makes them a little more spaghetti-like.
        If your slab is dead flat, and if your CDX ply is dead flat, you wouldn't need to do any of this, but my experience has been otherwise.
        I do another thing, too, to make the sheets really pliable.  With the circular sawblade depth set at 3/8", I zip four or five halfthru cuts across each 2x8 sheet of CDX, on the D underside, before setting it into the combed glue bed.
        It is a good idea to have some concrete blocks, or pails of water, or something with weight, to spot around if you have any panels that need help laying down flat.
    Constantin | Sep 26, 2005 04:47am | #4
    Oh nooooooo... :-P
    I'd consider the system from Roth. Insulated on one side, Aluminum on the other for great heat transfer, probably perfect for concrete slabs. The schedule you're describing will probably result in very little thermal response and large losses to the underlying slab.
    I wouldn't add sand to any system unless I needed a cheap insulator. The stuff is no good as far as adding mass is concerned. Floating system like stadler-viege, roth, wirsbo, etc. don't need additional mass anyway. If adding mass is your thing, put down a thermal break, put down the tubing, then pour a gypcrete or similar layer.
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
