I am planning a small (~24sqr ft) hydronic installation, and I am looking for recommendations for brands of material. I have recieved info from RTI, Rehau and Radiantech. Rehau seems the most different from the others, unique crimping and fittings, otherwise I don’t see much difference. Location: N. CA/SF Bay. Looking for any experience or recomendations.
Thanks,
Meserve
Can you confirm that you mean 2400 sf? You could handle 24 sf by spilling a cup of tea on the floor! <G>
Yes, 24 sqr.Ft., I am actually using the system to "cool" or maintain a temp. of ~55 deg. F, by running the cold water supply through it before it feeds my water heater. I am planning on Casting a slab w/ the tubing embedded, and insulated from the floor underneath.
Is that Radiantech as in the one in VT?
Yes, Radiantech is in VT
then run far away. crappy materials. bad (dangerous) design. scary stuff. and then they call the pros a rip off!
Thanks for the info. M.
