rafter layout
| Posted in General Discussion on April 27, 2007 02:09am
I seem to be doing more roof`s latley. is there a rule of thumb for droping the birds mouth on the hip rafter. I know the longer the run the more you have to drop it, but info on this topic is hard to find..
    FatRoman | Apr 27, 2007 02:32am | #1
    Have a look at this current thread. Might be what you need.
    http://forums.taunton.com/tp-breaktime/messages?msg=89089.1
  2. cliffy | Apr 27, 2007 02:49am | #2
    You need to shorten the hip rafter by a length equal to one half the length of a line drawn across the hip rafter at 45 degrees. For a hip that is 1 1/2 inches wide this equals 1 1/16 of an inch.
    This information is in any carpentry textbook used at colleges or apprenticeship programs.
    Have a good day
    CLiffy
  3. kpatrix | Apr 27, 2007 03:11am | #3
    The amount of the drop is not based on the run but rather the width of the hip as well as the pitch. Check out Joe's drawing in the other hip thread.
    John
    Edited 4/26/2007 8:11 pm ET by kpatrix
    1. JoeBartok | Apr 28, 2007 05:31pm | #4
      For bastard Hips created by the intersections of unequal roof slopes it's also best to offset the Hip rafter in proportion to the plan angles. This locates the Hip rafter in relation to the where the roof slopes would intersect or "plane in" if the Hip rafter were backed.
      Proportional Hip Offset and Hip Drop
      Example Hip Offset-Drop Calculations
      Hip Drop for Offset Hip Rafter ... the animated version : the blue line labelled "tan Hip-Valley Pitch Angle" is the "Hip Drop".
      Joe Bartok
      Edited 4/28/2007 10:34 am ET by JoeBartok
