Rafter span
| Posted in Construction Techniques on January 20, 2003 04:48am
I am checking for a friend, and cannot find span tables that apply.  60 psf snow, asphalt shingle roof over 5/8″ OSB, no applied ceiling beneath, just cold attic space over ceiling joists, 6:12 pitch.  What will a 2×10 SPF #2 span?
    BossHog | Jan 20, 2003 05:30pm | #1
    What species of lumber?
    Keep honking. I'm reloading.
    1. Boxduh | Jan 20, 2003 06:43pm | #2
      S-P-F, Canadian.
        BossHog | Jan 20, 2003 07:51pm | #3
        I'm having trouble coming up with any at the moment. I'll try a bit more as I have time...........I haven't had my coffee yet, don't make me kill you.
        BossHog | Jan 21, 2003 03:58am | #5
        The link Mark provided is the only thing I could come up with - He just got it posted before I did.
        I have some published tables I could fax to you if you need 'em really bad.Common sense isn't very common.
        1. Boxduh | Jan 21, 2003 04:45am | #6
          What I am missing, Boss, is the tables with the magic number of 60 psf snow on top.  The on-line calculator takes me up to 50 only.  If you have what I need on paper, tell me when you will fax, and I will make sure the line is clear: 518-523-7149
  2. MarkDikeman | Jan 21, 2003 01:07am | #4
    You can try this calculator.
    Yes, I am serious.   And don't call me Shirley.
  3. rickshort | Jan 21, 2003 06:53am | #7
    I looked up your rafters on my Canadain Span Book.
    62.7 psf roof rafters ( no ceiling)
    2x10's  spf # 1&2 12" oc = 18'4
                                 16" oc = 15'11
                                 24" oc =13'
     Reply if you need different spans.  If you add collar ties you can increase the spans of rafters.
Drafting the 2027 IRC
  • The New Old Colonial
