greeting all,
I need to cut some small holes in an old radiant ceiling and was wondering if anyone has a method of finding the wires as opposed to gently scraping back to find them.
thanks
Orbs
greeting all,
thanks
Orbs
the electronic Bosch stud finderwill locate them...
WOW!!! What a Ride!
Yeah, and probably one of those non-contact Christmas light testers would work.
A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
bump
is there something wrong with theanswers ya got???
a Greenlee 20011/00521 circut seeker will do the job too but the Bosch DMD4 Digitsl Multi-Detector is about 850/900$ cheaper...
WOW!!! What a Ride!
never tried one of those...
let us know if does...
WOW!!! What a Ride!
As a general rule, if you just start cutting you'll find the wires soon enough. Especially if the power's on when you do it. The trick is to NOT find the wires.
(Several types of circuit-tracing devices might be used. I had a cheap GB unit that would have done the job, but it quit working about a year back.)
Any of the heated gypsum panels I have removed were filled up pretty good with wires. I could not imagine getting around them.
